Require Rating or Set Default
Discussion in 'GeoCraft WordPress Theme' started by jumpgroove, Jul 4, 2013.
  1. jumpgroove
    jumpgroove New Member
    Is it possible to make ratings required - or make the default rating 5?
    Also, in which PHP file can I find the text "Rate this by clicking a star below:". I've done a search but can't find it and would like to make it bigger etc.
    Thanks!
    But yes you can change review text.
    Go to the
    geocrafttheme\library\text_domains\template_path.php
    Check image for reference.
