Reset options
Discussion in 'Forum Rules' started by drkevinhu, Feb 7, 2019.
  1. drkevinhu
    drkevinhu New Member
    I accidentally clicked "Reset options" bottom, every is gone. Is there anyway to restore it? Or I have to reinstall the theme? Looking forward your earliest reply!!
    Kevin
  2. akbar92
    Greeting from InkThemes,
    Do you have any backup file of your website?
    If you have then you can upload the backup file of your website.
    Also, you can contact your host provider they might have the backup file of your database.
    Let us know if you need further assistance we will be glad to assist you.
    Akbar
  3. drkevinhu
    Thanks, it is fixed.
  4. akbar92
