The themes auto resizes and squishes images after a user uploads them. How can I make it not do this??? Everytime someone uploads a picture its squished...
Hello, Theme contain nearly square frame for front page and ad single page slider. So if we add images with totally different dimension then this issue will occur. Upload images of dimension similar to (280 x 230)px. They will look good.
So you are telling me I have to tell my customers to resize their images? Not going to happen. Is this not an issue for others??!! How the fuck do you get away with such flawed features.
Hello, It is the default functionality of WordPress to resize the images, We are not telling to use recommended dimension images that is suggested but try to use that dimension because ads are looks good in that dimension, We are just want to explain that if you are using portrait images for your ads and it will display in your single page or in a slider it will definitely squished, You just try to use square images as much as possible it will work fine, You can also add notice below the image upload section about the dimension of images. We also suggest you to use Wp Image Size Limit plugin, Download it from WordPress.org http://wordpress.org/plugins/wp-image-size-limit/
