Responsive Images
Discussion in 'Traffica WordPress Theme' started by dchs2015, Nov 19, 2015.
  1. dchs2015
    dchs2015 Member
    Delaware County, Ohio, USA
    I don't see images (outside of sliders or galleries) changing size at the screen size changes.
    Is that not part of Traffic's responsive framework?
    Is there something I need to do to make an inserted image responsive?
    such as: express size in em or % rather than px
    Is there something about the WP image insert that prevents image being responsive?
    such as: custom styles for each image
    Thank you for your help, as always,
    Rick
  2. nitin
    nitin Guest
    As far as I can find, you are running on an old version of the theme. Kindly update your theme to the latest version.
    This would be solving all your problems.
    Nitin
  3. dchs2015
    dchs2015 Member
    Nitin,
    Thank you for responding.
    I am currently at v 1.1.5 and the latest is v1.1.6.
    I do not see anything in the change log to suggest responsive has changed between those versions.
    I will update, but how do I do that without wiping out the changes you made to Customize Slider Images?
    Rick
  4. nitin
    nitin Guest
    Hi Rick,
    Thank you for getting back to us.
    We have forwarded your query to the concerned department.
    As InkThemes has been receiving a high volume of support requests our developers are busy at this moment, I will try to pull them on your issue and will get back to you with a positive response ASAP.
    Hope you understand..
    Warm Regards!
    Nitin
  5. dchs2015
    dchs2015 Member
    Nitin,
    I understand that support is busy.
    If you could tell me which files were modified or added to add the image corners, I can protect them from the update to Traffica 1.1.6
    That way we can see if the update takes care of the responsive issue.
    Rick
    http://barnatstratford.org
  6. priya
    Hello Rick,
    I am sorry to say but I am unable to access your site.
  7. dchs2015
    dchs2015 Member
    Priya,
    Nice to hear from you again.
    If you are trying to login use password Inkthemes!Su99ort
  8. dchs2015
    dchs2015 Member
    Priya,
    I have looked at the changelot and V116 does not effect image responsiveness.
    My original request was: images on pages ( not in slider or gallery) do not change size as media gets smaller.
    I expect a responsive theme to do that.
    Is there some special way that a single image should to be added in Traffica to be responsive?
    Is there something about the way WP insert images (classes or fixed sizes) that is blocking responsive?
    How can I get the images to resize to different media devices?
    I look forward to any advice you can provide.
    Rick
    barnatstratford.org/wp/
  9. priya
    NOTE: Please don't use to share your credentials at the forum, send your details at our mail id i.e. [email protected]
    Hello Rick,
    I have done all the changes in your site,
    Kindly check and reply.
  10. dchs2015
    dchs2015 Member
    Priya,
    I have responded to you under Customize Slider.
    I will send you new site details by email.
    Thanks and Regards!
    Rick
  11. priya
    OK! Rick,
    Will get back to you soon..
