Responsive Issue
Discussion in 'ColorWay WordPress Theme' started by spoonboy90, Aug 1, 2013.
  1. spoonboy90
    spoonboy90 Active Member
    1. Is there a way to move the slider caption box up further in this view
    2. Can the horizontal line be moved down more in this view to enable the mobile navigation box to fit between them.
    3. Can #2 be done for this view and also move the 3rd horizontal line down below the slider where it should be
    You will need to log into the site to view the pages... I have emailed you a username and password.
    Many Thanks
    Jamie
    Hello Jamie,
    All work done. Please check your site.
  3. spoonboy90
    Hi Nitesh,
    Perfect, thanks very much
    Regards
    Jamie
