Rethink Theme and translation
Discussion in 'ReThink WordPress Theme' started by tuxlog, Sep 18, 2013.
  1. tuxlog
    tuxlog New Member
    I have bought the rethink theme and I (re)think it is a really good theme. :)
    Now I want to translate the theme to my language and found that it is a bit messy in preparation for translation.
    • There some words tagged correctly with textdomain "rethink"
    • There a some words tagged incorrectly with textdoamin "spotmoto" (in products.php)
    • And a whole bunch of words isn't tagged at all (e.g. in comments.php).
    Is there a solution for this? Any ideas? Or are there plans to improve this in further releases?
    Thanks in advance, Hans
  2. Harmeet
    Harmeet Support Staff
    Thanks a lot for informing us.
    We will correct it in the theme and update it in next 24 hours.
    And we are bit getting what you are trying to say in this line "And a whole bunch of words isn't tagged at all (e.g. in comments.php)". So could you please explain it more, so that we can check it.
  3. tuxlog
    tuxlog New Member
    Thank you for responding so quickly and for the anncouncement for a quick fix.
    What I mean is if you take a look at e.g. comments.php which is delivered with the rethink theme, you will find various textstrings which are not prepared for translation.
    e.g.
    <p class="nocomments">Comments are closed.</p>
    which probably should be
    <p class="nocomments"><?php _e('Comments are closed','rethink');?>.</p>
    If strings are not preapred for translation by wrapping them into a __ or _e function, it is not possible to translate the theme without editing the original theme files and the work has to be repeated after each update.
    The __ and _e functions are also missing in the complete backend part of the theme.
    I hope I was able to explain what I mean.
    Thank you very much for your support :)
  4. tuxlog
    tuxlog New Member
    Okay, I have added about 200 missing function calls myself. There are also some 404 problems with missing files and some unused code in the theme which I fixed too.
    If you are interested in the corrected version, let me know. Maybe we will find an interesting arrangement for both of us. :)
    Thank you and regards, Hans
