Could you please direct me to where i can edit the No Review, % Reviews text etc as you can see from my site http://www.stokebusinesslistings.com/all-listings/page/4/ the plural isnt working. I've changed the following code in the module_functions.php file but it doesn't seem to make any difference, also need this to work for the searches too! Code: if ( false === $zero ) $zero = __( 'No Reviews' ); if ( false === $one ) $one = __( '1 Review' ); if ( false === $more ) $more = __( '% Reviews' ); if ( false === $none ) $none = __( 'Reviews Off' ); I'm using version 1.7.9 and I don't wish to upgrade to 1.8
Hello, For search page review. Sending "template_search.php" and "module_functions.php" file download and replace them with your current theme files.(Do not delete old files keep them for backup) For other pages review text. Go to geocrafttheme\library\text_domains\template_path.php Check image given below.
Thanks Nitesh Is there a particular reason that on the search page 'No Reviews'/'1 Review' etc is not a link but it is on other pages? and For anyone else interested there is also another instance in template_path.php around line 80 to pluralise more than 1 listing Code: define('REVIEW',__('Review',THEME_SLUG)); to Code: define('REVIEW',__('Reviews',THEME_SLUG));
