Reviewcentre.com badge not working with pro version
Discussion in 'Figero WordPress Theme' started by onlineunlocks, Jun 24, 2013.
  1. onlineunlocks
    onlineunlocks New Member
    I had a reviewcenter.com badge on the website and works ok with the trial/lite version of figero also with other themes,but dos not work with the pro version,any idea why?
  3. onlineunlocks
    The website where I installed the pro version and the review not working is this one:
    http://htcunlock.us/
    the one with the lite version that works is
    http://blackberryunlock.us/
    Here is the code from review center:
    <!-- This code is the property of www.reviewcentre.com. By adding this code to your site, you agree not to modify the code in anyway -->
    <link href="http://www.reviewcentre.com/css/seo_badge.v3.css" rel="stylesheet" type="text/css">
    <script type="text/javascript" src="http://www.reviewcentre.com/js/RC.SeoBadge.v3.min.js"></script>
    <script type="text/javascript">RC.Badge.initialize("http://www.reviewcentre.com", 1948525)</script>
    <div id="rc-badge-wrapper" class="style-340x150 color-white" style="width: 340px; height: 150px; ">
    <div class="rc-top-corners"></div>
    <div class="rc-content">
    <div class="rc-logo">
    <a title="Review Centre - Consumer Reviews" href="http://www.reviewcentre.com">http://www.reviewcentre.com</a>
    </div>
    <p class="rc-rating"></p>
    <div class="rc-stars"></div>
    <div class="rc-overview">
    <p class="rc-category"><a href="http://www.reviewcentre.com/products3503.html">Mobile Phone Unlocking Services</a></p>
    <p class="rc-item"><a href="http://www.reviewcentre.comhttp://w...unlocks-www-onlineunlocks-com-reviews_1948525">Onlineunlocks www.onlineunlocks.com</a></p>
    <p class="rc-date"></p>
    <p class="rc-extract"></p>
    </div>
    </div>
    <div class="rc-write-review"><a href="http://www.reviewcentre.com/write-a-review-1948525.html">Write a review</a></div>
    </div>
  4. onlineunlocks
    Any update on this please?
  5. Nitesh
    I have checked your site review is working fine in both site.
    Also checked code you have posted above in both lite and pro.
    It is working without any problem.
    Please do let me know exactly at which point you are getting issue.
  6. onlineunlocks
    On the pro version is not fetching data from them,shows an empty box,does not show the current rank,or last review[​IMG]
    and
  7. Piyush
    Before the previous reply we were seen your website (http://htcunlock.us/), it seems that you had pasted that badges code in the home page two column panel but now we are unable to find that badges on your website(http://htcunlock.us/).
    Please specify with the help of sceenshot images that where you are putting that badges code.
  8. onlineunlocks
    I found out the problem,is a jquerty ,seems the pro theme works using the lattes 2.x version but which like said on their website does not support IE 6/7/8,also seems the badge also not working with this latest jquerty version. So uploaded version 1.10.1 ,and with this version the badge works but the slider from home page is no longer working
  9. onlineunlocks
    When I add this in head
    <script type="text/javascript" src="jquery-1.7.2.min.js"></script>
    the badge starts working,but the slider from first page is no longer working
    That is happening for all jquery versions except 2.0
  10. onlineunlocks
    any ideea how to make the first page slider still work and be able to call jquery from head as needed for a select list to
    ex:<script type="text/javascript" src="jquery-1.7.2.min.js"></script>
  11. Nitesh
    Thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
    I will check and resolve your issue
  12. onlineunlocks
  13. Piyush
  14. onlineunlocks
    Still having problems with this,have updated wordpress and used your theme and now is same problem;what fix did you do then so the badge worked to change to this version also
  15. Piyush
  16. onlineunlocks
    Yes that is the site you fixed for me,but tried the theme with new WordPress version and is not working,on other website:
    http://blackberrymepunlock.com/
    Already sent email with login details
  17. Piyush
  18. onlineunlocks
    Yes,I see , thanks.Can you let me know what file was the problem or what exactly needed to be change,as in case I update the otehr website to new wordpress not to bother you again
  19. Piyush
    In your site there are two js file
    1. samsungunlock.us-sellect.js
    2. jquery.selectbox-0.2.min.js
    The path of these js files was given incorrect in the code which is in the Right Column Description section, that's why review center badges not working.
    Just we are corrected their path in that code, after that it is working fine.
    See the image for reference.
