Right hand navigation bar
Discussion in 'Photomaker WordPress Theme' started by blackdog2020liz, Jun 12, 2014.
  1. blackdog2020liz
    blackdog2020liz Member
    Western Australia
    I am building a site I don't wish to run as a blog. How do I remove the Recent comments, archives, meta etc?
    Many thanks
    Liz
  2. blackdog2020liz
    Western Australia
    any help on this please?
  3. Gourav
    Go to
    Appearance > Widget
    Drag "Text" widget and add paragraph tag there and drop it in Primary widget area, This will solve your issue.
    Gourav Shrivastava
  4. blackdog2020liz
    Western Australia
    Hi Gourav, I'm not sure what you mean. What is a paragraph tag? Will this remove eveything from the right hand navigation bar except for the page names?
    Many thanks,
    Liz
  5. Gourav
    Yes, it remove everything from the right hand navigation bar except for the page names.
    Paragraph tag:
    <p></p>
    Gourav Shrivastava
  6. blackdog2020liz
    Western Australia
    Okay, I added a new text widget to the primary widgets and entered that code but nothing changed. www.carlonbuilding.com.au
    Thanks for your help.
    Liz
  7. Gourav
    Thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
    I will check your issue.
    Gourav Shrivastava
  8. blackdog2020liz
    Western Australia
    Hi Gourav,
    Have you had a chance to check this for me?
    Many thanks
    Liz
  9. kbarnold
    kbarnold Member
    Hi Liz,
    I had the same issue. I went to Widgets and removed ALL widgets from Primary Widget Area and then dragged an empty Text widget to the Primary Widget Area and saved. Refreshed Home page and everything was gone from menu bar except page names. I think the key is to remove all widgets first and then add the blank text widget. I didn't even need to put the paragraph tags in to make it work. Good luck.
    Kevin
  10. blackdog2020liz
    Western Australia
    Hi Kevin,
    Worked perfectly. Thank you so much!!!
    Liz
