right side of website is cut off
Discussion in 'BlackWell-WordPress Business Theme.' started by sandradohn, Jan 4, 2015.
  1. sandradohn
    sandradohn Member
    Hi There, I am having trouble with the right side of the website not showing up on my screen....I am using a regular size laptop and chrome. The website is marchwebdesign.com Thanks, Sandra
    PS I have attached a screenshot.
  2. praveen
    praveen Support Staff
    Hi sandra,
    This is default functionality added in this theme.
    When you will click on menu tab, you can see the page in full screen.
    Praveen
  3. lkodsmann
    lkodsmann Guest
    Is there any way to remove this default functionality, so that the entire website section is resized when the menu is open? I don't want website visitors to have to turn the menu off in order to see the full homepage...
  4. praveen
    Hi Sandra,
    Please provide us your wordpress login detalis at [email protected].
    We will make menu off by default.
    Praveen
  5. lkodsmann
    lkodsmann Guest
    I don't want the menu off - I want the menu on, but the right hand side to also display.
  6. Pramod
    Pramod Guest
    Hello lkodsmann,
    Unfortunately there is not a way to remove this.
    Pramod
  7. lkodsmann
    lkodsmann Guest
    Why not? The right-hand side is coded to be responsive, why isn't there a way to make it so that the entire site still displays when the menu is open? I guess I'll go find another theme, which is very disappointing. It seems very unfriendly to website visitors to not be able to see the entire site.
  8. Naveen
    Hello lkodsmann,
    Naveen Kolhe
