Robot.txt, SEO Options
Discussion in 'Andrina WordPress Theme' started by rapidresults, Jan 3, 2013.
  1. rapidresults
    rapidresults Guest
    Hi:
    When I search my website, michelelisasalon.com, instead of getting a description of the site underneath the title, I am getting this message:
    A description for this result is not available because of this site's robots.txtlearn more.
    I have added meta tags, descriptions and enabled the site the be "searchable".
    Can you please me help correct this issue or point me in the direction to fix this?
    Thanks so much.
    Valerie
  2. analyste
    analyste New Member
    Hi, having same problem - no support there!!!!- after having set up (I think!) a login application (S2members). The problem is not the robot.txt which is easy to modify, my problem is to find this file. I have read some developpers set it up to be send via php, is this the case for cloriato ?
    Basically so, question is where to find it ? thanks in advance
  3. Nitesh
    I have searched your site. It is showing correct description.
    Just wait for some time google will again read your site again and your issue will be automatically resolved.
  4. analyste
    analyste New Member
    ok thanks anyway, i'm actually really enjoying the theme!
