1. Is there a way to make the testimonials (both image and text) slide? 2. How can I alter the colour of the background (I want the yellow to be a bit lighter than the standard yellow you provide) Thanks.
1. Unfortunately there isn't a way to do that with our theme unless you custom code something up. Sorry. If this isn't something you're able to do then you would need to hire a developer for this. 2.Go to Color > yellow.css present in your theme directory and change your color there and also change images as per your requirement.
