Roomshare Pro Theme broken
Discussion in 'BlackWell-WordPress Business Theme.' started by svonfischer, Dec 29, 2020.
  1. svonfischer
    svonfischer New Member
    Site name: soul-friends.org
    Probably from a WP upgrade...
    Here are the errors:
    Uncaught TypeError: Cannot read property 'tagName' of undefined
    at HTMLUListElement.<anonymous> (jquery.animate-enhanced.min.js?ver=5.6:18)
    at Function.each (jquery.min.js?ver=3.5.1:2)
    at s.fn.init.each (jquery.min.js?ver=3.5.1:2)
    at s.fn.init.d.fn.animate (jquery.animate-enhanced.min.js?ver=5.6:13)
    at s.fn.init.S.fn.<computed> [as fadeIn] (jquery.min.js?ver=3.5.1:2)
    at jquery.superslides.js?ver=5.6:621
    at Superslides.fade [as animation] (jquery.superslides.js?ver=5.6:299)
    at Superslides.animate (jquery.superslides.js?ver=5.6:608)
    at jquery.superslides.js?ver=5.6:92
    at dispatch (jquery.min.js?ver=3.5.1:2)
    /#1:1 Failed to load resource: the server responded with a status of 500 ()
  2. akbar92
    Warm wishes from InkThemes,
    Akbar
  3. svonfischer
  4. svonfischer
    Still broken since WP upgrade. I made the site work for a bit by downgrading, but a recent refresh for security broke it again.
  5. shemaela21
    shemaela21 Guest Staff Member
    Warm Wishes From InkThemes,
    Kindly send the below-mentioned credential details to [email protected].
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    We will check the issue and will let you know about it.
    Shemaela
