Hi Inkthemes, RTL feature is not working. I choose RTL profile in Styling options but it doesn't work. Could you look into the issue. Thanks.
Hello, This issue maybe because of plugin (if installed). So please deactivate all plugins to see if this resolves the problem? If this works, re-activate the plugins one by one until you find the problematic plugin(s). Thanks & Regards Gourav Shrivastava
Hi Gourav, It was a fresh wordpress installation and no plugin activated. You can try it by yourself by installing a fresh copy of wordpress and colorway pro theme. Waiting for your reply. Thanks, R.
Hello, Could you please provide the following information listed below. Thread Link: http://www.inkthemes.com/community/threads/rtl-support-for-colorway-pro.10188/ Your Website URL: WordPress Username: WordPress Password: Send this information on our email at [email protected] We will check and try to resolve your issue.
