Hi, I have some question to Salejunction theme, please help me: 1) how to change or translate the word "in total" in the header on left position? 2) how to change or translate the Register page in the header on right position? 3) how to insert a Google reCAPTCHA on Woocommerce Checkout page? 4) how to restore the checkbox "Create Account User?", i can remove the cache of Woocommerce? Now I see the box "Password". 5) how to remove or translate the widget? For example, Search Product widget ? 6) how to remove the widget Categories, Archives, Search in the Shop page? I don't have any widget in the Widget menu. Thanks for all, best regards Andrea.
Hello, Our theme is translation ready, you can use the PolyLan translation plugin to translate the website content, here is a link to the plugin: https://wordpress.org/plugins/polylang/ For (1 & 2). Will you please share the translated string which you want to display in a header ("in total" & Register). 3. You can use plugin to insert a Google reCAPTCHA on WooCommerce checkout page, here is a link to the plugin: https://wordpress.org/plugins/wp-recaptcha-integration/ 4. It would be better for us to understand your query with the help of some edited screenshots. Please share some screenshots of the concerned areas of your site. So that we can deliver you an exact and appropriate solution to you, PS: You can create your screenshots using screenpresso (http://www.screenpresso.com). 5 & 6 . You can use a blank text widget to remove widgets like search product, categories, archives, etc. Regards, Akbar InkThemes.com
Hi Akbar, Thank you for the fast reply. 1. I would translate the word "in total" -> "in totale"; and I would translate the tooltip "View your shopping cart" in "Vedi il tuo carrello" -> https://screenpresso.com/=h9zxc (1) 2. I see the Register page in this mode, but i would change the name of the form -> https://screenpresso.com/=K9kHf -> also I can modify the Sign form ? 3. it's ok for the checkout form, but don't protect the Contact Page create from "Contact Page" template. How to protect this form with reCAPTCHA? How to insert o modify this page template "Contact Page" adding the GMaps and text? 4. in attach the problem: I see always the form Password and I don't see the checkbox "Create Account User". https://screenpresso.com/=h9zxc (4) 5. I remove the widget from the Appereance -> Widget -> Primary Widget Area. Where I can insert the blank test widget? -> https://screenpresso.com/=K9kHf Thanks for all. Regards, Andrea.
5. I remove the widget from the Appereance -> Widget -> Primary Widget Area. Where I can insert the blank test widget? -> https://screenpresso.com/=K9kHf ---> OK, I resolve this! Thanks!
Hello, It requires some manipulation in the source code of the theme, we will do it for you. Please share your WordPress admin credential details at [email protected] along with the thread link. WordPress Website URL: - WordPress Username: - WordPress Password: - Regards, Akbar InkThemes.com
