Sample Data set for GeoCraft
Discussion in 'GeoCraft WordPress Theme' started by afreeth, Feb 22, 2017.
  1. afreeth
    afreeth New Member
    Good afternoon,
    is there Sample Data set for GeoCraft Theme available?
    Many thanks
    Andrew
  2. tony21237
    tony21237 New Member
    The theme comes loaded with data/placeholders.
  3. nitin
    nitin Guest
    As soon as you will install the theme, and you will go to Dashboard-> Appearance-> Themes. You will see a message on the top as 'Would you like to populate sample data on your site?', just click on 'Yes Insert Sample data'.
    The sample data will be installed.
    Hope this helps...!
    Nitin
  4. michael_ontracto
    michael_ontracto New Member
    I tried that as well "As soon as you will install the theme, and you will go to Dashboard-> Appearance-> Themes. You will see a message on the top as 'Would you like to populate sample data on your site?', just click on 'Yes Insert Sample data'." and nothing installed itself, clicking the following button showed a blank page.
  5. Naveen
    For your information, it may happen that some of your plugins are conflicting in your site,
    You are requested to deactivate all of your plugins once and check your site again,
    Then activate one by one your plugins checking result on each activation,
    Hope this will let you figure out the problematic plugin.
    Warm Regards!
    Naveen Kolhe
  6. michael_ontracto
    Tried disabling plugins still the same, not working......... Exasperating...
  7. Naveen
    Kindly, share your WordPress admin credentials at [email protected] along with this thread URL:
    WordPress site login URL:
    WordPress admin username:
    WordPress admin password:
    We will check and do the needful.
    Warm Regards!
    Naveen Kolhe
