Schema.org Markup for GeoCraft Theme
Discussion in 'GeoCraft WordPress Theme' started by dwalke3, May 11, 2017.
  1. dwalke3
    dwalke3 New Member
    Does anyone know of a plugin that is compatible with the GeoCraft theme and will implement schema.org markup for the star ratings in the theme so that the stars will show up in search results?
    I'd also like to implement schema markup for breadcrumbs and local business.
    Thanks for any help you can give.
  2. izhak007
    izhak007 Member
  3. nitin
    nitin Guest
