script showing
Discussion in 'Blackriders WordPress Theme' started by katsu914, Sep 7, 2015.
  1. katsu914
    katsu914 Guest
    As you can see on http://fmc.link/sgp/, the scripts are showing under the latest blog section.
    What is the problem?
  2. nitin
    nitin Guest
    It seems that one of the coded function which is intended to work in the background is showing it's script on the page.
    Believe me, that's not an issue. Fixing this requires some customization in the source code of the theme.
    We will fix it for you.
    Nitin
  3. katsu914
    katsu914 Guest
    Dear Nitin,
    Sent my details by email!! Please kindly help me!!
  4. nitin
    nitin Guest
    I regret to inform you that we haven't received any mail from your side.
    Kindly check and re-send the mail.
    We would be glad to help you.
    Nitin
