Search and Lcation Box Data Capture
Discussion in 'GeoCraft WordPress Theme' started by gaamain1, Oct 9, 2015.
  1. gaamain1
    gaamain1 New Member
    Is there a way to capture the text a user enters into either of the two search boxes on the Home Page? If it cannot be done by adding code, is there a plug-in that someone knows of that works with this theme?
    I would like to be able to look over the captured data to see if there are multiple searches for common locations to see if I need to add them to the categories.
    Thanks.
    I am sorry, but it would not be possible from our end since there would be requirement of a lot of customization in the source code...
    Hope you understand.
