Search Categories and Tags
Discussion in 'VideoCraft WordPress Theme' started by academybridge, May 26, 2014.
  1. academybridge
    academybridge Member
    Please advise best solution for category/tag search (plugin or widget)
    Kind regards
    PAX
    G
    Download updated version of theme from your members area and upload it, This will solve your issue.
    Login here: http://inkthemes.com/members/member/index
    For changes please check the changelog.txt file, present in your theme directory
    == Changelog ==
    = Theme Name: videocraft Theme Pro=
    = Version: 1.2.2 =
    1. Featured Video Option error fixed.
    = Version: 1.2.1 =
    1. Featured Video Option On Homepage added.
    = Version: 1.2.0 =
    1. Upload section button text improved.
    2. Social sharing options added.
    3. Submit landing page improved.
    4. Recent videos widget on home page changed to Random videos.
    5. Searching improved with Video Category & Tags.
    = Version: 1.1.3 =
    1. Video made using iPhone can be uploaded now to VideoCraft.
    = Version: 1.1.2 =
    1. Image Captcha Added during user registration.
    2. Latest JW player Added.
    3. edit video category issue fixed.
    4. Video now uploads with progress bar.
    5. Video Search widget added.
    = Version: 1.1.1 =
    1. Video Category Widget Dropdown Issue Resolve:
    = Version: 1.1.0 =
    1. Mail Function Added:
    If a user submits a video, Admin receives an email of pending approval. Once the admin approves the video, User gets an email that his video is made live.
    2. Text Domains Updated:
    Added translation strings on the theme to make it simple to translate the theme in any language.
    3. Comment Style Updated:
    Few styling adjustments made in the commenting system of the VideoCraft Theme.
    4. Style.css updated:
    Enhanced Visual appearance of the themes to make it look even more awesome. Fixed appearance of theme on Mobile and Tablet views.
    = Version: 1.0.4 =
    1.Terms And Condition Added In Signin Form.
    = Version: 1.0.3 =
    1.Mobile Menu Problem fixed.
    = Version: 1.0.2 =
    1.Slow loding issue fixed.
    = Version: 1.0.1 =
    1.ipad and iphone video problem solved.
    2.Upload button problem solved.
    = Version: 1.0 =
    * * videocraft Theme is created on 1/09/2012.
    Gourav Shrivastava
  3. academybridge
    Thank you
    I have v1.2.0 installed. Do I need to make some coding changes to add tag/category feature?
    This is beyond my capability can you support?
    Kind regards
    PAX
    G
  4. Nitesh
    We have improved searching functionality in version 1.2.0.
    If you are using same version then it should work on your site.
    Please share your website link so that i can check where the problem is.
    Nitesh Raghuwanshi
  5. academybridge
    www.academybridge.org
    I do not know where to setup tag/category search box/feature
    Kind regards
    PAX
    G
  6. Nitesh
    There is no need of any extra work for setting up tag and category search.
    I have checked your site search functionality and tag and category search is working fine.
    Suppose you have a category "Career" and if we submit search for "Career". Then the result will be all videos. Which are under "Career" category.
    So i don't found any problem in it.
    Nitesh Raghuwanshi
  7. academybridge
    Thank you
    Yes the search for "career" shows career videos, but they are different (order, not in category etc.) than career category (most recent).
    Is there some way to search category and get same list as in the actual category (date order of entry etc.)
    Thank you
  8. Gourav
    Gourav Shrivastava
