Search engine
Discussion in 'General InkThemes Discussion and Feedback' started by globaluna, Dec 12, 2015.
  1. globaluna
    globaluna New Member
    Slovenia
    Hello dear developers,
    do you have any search engine where you can find all about specific topic .
    For example : I bought SmartBooking WP Business Theme and want to see all it was written her on forum or I have to browse manually over all webpage ?
    Second, I miss info if you did any updates on this theme ? Where to look it?
    I have some problems and before I continue I would like to check if there was a problem in the code or somewhere else.
    kind regards and thank you in advance for your reply
    with respects
    Irena Rebula
    Hello Irena,
    As per your above issues, solutions are accordingly..
    1) From where you can find all about the specific topic...
    So let me tell you that there is a changelog file within the theme from where you can get all the information about the theme...
    2) I miss info if you did any updates on this theme? Where to look it?
    All the latest updates of the theme will be available in the members area and you can easily get all the updates related to your theme from your members area.
    Hope you will find it helpful.
  3. globaluna
    Slovenia
    Hi Priyanka,
    thx for y reply.
    ad1. ) I understand , but I would suggest you to post in member area some documentation where will be evident all changes you did on specific theme,widget etc .... we would appreciate it . For example like WP where you find in dashboard alerts to updates . In your case I have first, to unzip and than watch changelog file ...this is so uncomfortable..... thank you.
    ad.2) I overwrote(upgrade) only appointment plugin. It seems it works , but I will be sure after some time. I attach log file.
    I would appreciate if you upgrade Appointment plugin with :
    1. place of appointment (for example where taxi will pickup the person) or at least you add personal msg to mail .Now msg is not added to mail msg.
    2. appoint. csv file to be already arranged into excel columns ( each field in separate column)
    Yes your reply was helpful.
    Thank y again and kind regard
    Irena
    Globaluna d.o.o.
    Hello Irena,
    We really appreciate your suggestions...:)
    We will definitely discuss with our developers and try to implement in our next update as well and will notify you the same..
