Search results not displayed properly for CalPress events
Discussion in 'Infoway WordPress Theme' started by roboticsbeyond, Jun 10, 2014.
  1. roboticsbeyond
    roboticsbeyond New Member
    I am using the free version of CalPress. When I use the WordPress search function, the search results page is not displaying properly if there are CalPress events returned. I don't know if this is a CalPress problem or a search results page problem.
    My website is www.roboticsandbeyond.org. The search bar is in the footer. Type in "minecraft".
    Our themes are compatible with almost all the plugin available in WordPress.org but there are thousands of plugin available on WordPress.org and some are regularly updating and some are not updated from many years therefore it is not possible for us to check every plugin with our theme, So you can search any alternative of that plugin.
    Or
    You can also contact to plugin related support forum. They will help you.
    Gourav Shrivastava
  3. roboticsbeyond
    Hello Gourav,
    Thank you for your response. Could you tell me how the search results are displayed? Is that done via a php file in the InfoWay theme? Perhaps I can investigate that.
