Search results page not working right
Discussion in 'VideoCraft WordPress Theme' started by kemteck, Feb 5, 2015.
  1. kemteck
    kemteck New Member
    Greetings, just purchased and installed the VideoCraft theme for my website (ApartmentVideos.com) - upon using the Search on the home page with words "saint paul" - the results page shows all the correct videos with that tag, however if you click into each result, it is going to one specific result for all of them named Saint Paul, MN “Sibley Court Apartments”. Could use some support on this. One other note is when I inspect the element for "Saint Paul, MN "Larpenteur Manor Apartments" the permalink is for the "Sibley Court Apartments", not sure where that went wrong or where to edit that, could use some support. Not sure if my tech guy will fix this before I get a response though. Also, I have no plugins active either. Thanks for any help.
  2. kemteck
    kemteck New Member
    Solved on our end, tech guy said he had to do a little bit of a "hack" to make it work, just a heads up, so my examples above won't be of any use.
