When I search a business on my site, and I type a location... If I type Pensacola it works fine if I type Pensacola,fl. it comes back no results. if I add a space...Pensacola, fl. it works fine. is there any way to make it more forgiving on format?
We have used normal search form there, if you are looking for something with advanced features then, you can use the following search in your site: https://wordpress.org/plugins/ajax-search-lite/ I hope you find it helpful. Warm Regards! Naveen Kolhe InkThemes.com
Hello, It would be better for us to understand your query with the help of some edited screenshots of the concerned areas of your site. So that we can deliver you an exact and appropriate solution to you, Looking forward to hearing from you soon. Thanks & Regards! Akbar InkThemes.com PS: You can create your screenshots using screenpresso (http://www.screenpresso.com).
Hi, We need WordPress admin credentials to figure out the issue. Kindly send the below-mentioned credential details at [email protected] along with the thread link. WordPress Website URL: - WordPress Username: - WordPress Password: - We will try to fix your issue. Regards, Akbar InkThemes.com
