this is the same compatibility issue we have when using his popular seo plugin with our other sites on your themes. any suggestions?
hi and thank you pramod. that did not fix the issue. here is following your directions: - The Number One Name In Local Coupons! (see it left out the site name) here is the issue: CouponEnterprises.com - The Number One Name In Local Coupons!CouponEnterprises.com (see name of site repeated) thank you and only seems to happen with joosts seo. have a great day, mark;-)
Hello ! This is not a compatibility issue. You are using two time its title one in theme and another in plugin so remove the title in theme. To fix this follow below image. Thanks & Regards Pramod
