Hey there, my theme use to have select drop down working. Now it seems to not even pass through and hold the variable. I have tried to even go about deleting and re-creating the exact same select with the same variable except nothing is working. I was wondering if I could get someone to take a look. -Kent EDIT: Correction: Only ONE select drop down field is allowed at a time? The others do not seem to pass through the variable.
Hello Kent, You can use multiple select fields at a time. Just keep there "HTML variable name" different.
I am doing that, except the fields are not getting passed through... I do not believe I have done anything to edit thing functionality. Any chance someone can take a look?
Did a quick test on a new test server with no plugins, and the 1.7.9 geocraft theme and am still encountering these issues. I can supply you with a test login to both my customized and 1.7.9 blank geocraft theme. See attached for picture explanation of the problem. Please test on your end, and check back.
Hey guys, just seeing if this is being corrected, as it is one of the things preventing my launch. All the best, -Kent
Hello Kent, Please try latest version (1.8) of theme. This issue is not occurring in it. You can download theme from your members area.
Thanks again Nitesh! It is working in 1.8. I was wondering if you could supply me with the documents that you adjusted or altered to get this to work? IE: dashboard_functions.php or any other theme files that I may need to edit. All the best, -Kent Oliver
