SEO setting for home page and other pages
Discussion in 'Local Business WordPress Theme' started by skon, Feb 28, 2013.
  1. skon
    skon Member
    Norwood, Massachusetts USA
    I'm trying to optimize my site http://homespecialistsinc.com. I noticed that H2, H3 and H4 are used for multiple headings on my home page. Where can I change them so the heading all have a different H value?
    I ran an SEO report (http://SEO-Analyzer.org) that told me my home page had no Meta Description, but I set the Meta Description in my Local Business Pro Options. How can i fix this?
    How can I set Alt-tag for images on the home page slider?
    How do I set my Title, H1, Alt-tag and other SEO settings for my other pages?
    Will an SEO plugin solve these issues? If so, do you recommend an SEO plugin that works well with this theme? I noticed in a comment in another thread that the WordPress SEO by Yoast may have issues with this theme, and that you recommended All in One SEO - do you mean "All in One SEO Pack by By Michael Torbert"?
  3. skon
    skon Member
    Thanks for your reply, I really appreciate that you reply to questions quickly. Great support!
    I downloaded the All in One SEO plugin and it looks good. Any idea when the update for multiple <h1> tag will be available?
    Is there a way to set Alt-tag for images on the home page slider, and for widgets?
    Thanks.
  4. skon
    skon Member
    I am still awaiting your reply to this question. Is there a way to set Alt-tag for images on the home page slider, and for widgets?
    Thanks.
  5. Nitesh
    Hello Skon,
    Sorry for the delay.
    Theme is ready for you in your members area. You can download it from there.
    For alt tag.
    Go to the
    Appearance > Editor > front-page.php
    and search "alt" and add your alt text, Where search result point you.
    Check image for reference.
  6. skon
    skon Member
    Hi Nitesh, Thank you so much for your help! The alt tags worked just fine.
    I don't know what you mean about downloading the theme from the members area. All I saw was a list of member's. I saw the Local Business Theme 1.1.5 available on the WordPress update page, but I'm using the pro version of that theme so I didn't think that was what you meant.
    Should I be somehow putting the changes to front-page.php into the custom css page in the styling options page?
    Also, I read about creating a child theme so that when theme is updated, my modifications are preserved. Is this what you advise, or do I use the custom css page you provide?
    Thanks again!
  7. Gourav
    For downloading updated version of Local Business theme
    Login here: http://inkthemes.com/members/member/index
    At the time of update,If you have make change in .php files then you will loss your changes.Your theme option content and custom css will remain intact.
    Note:- Download child theme attached and upload it.
  8. skon
    skon Member
    Thanks Gourav, I've downloaded both files.
    Any instructions on how to use the child theme?
    By the way, is the Local Business Theme Pro a stand-alone Theme, or is it dependent on the free version? I guess I'm asking if I have to update the free version as well.
    Steve
  9. Nitesh
  10. skon
    skon Member
    Hi Nitesh,
    Thanks for the link to the child instruction page. I'll try it next chance I have.
    Steve
