SEO Settings
Discussion in 'Blackriders WordPress Theme' started by gmarwick, Jun 4, 2015.
  1. gmarwick
    gmarwick New Member
    I see teh yoast seo plugin in not compatible with the BR theme?
    Where shout I set the sites SEO settings which will show up in the Search engines discription?
  2. Sobhagya
    Sobhagya Guest
    Hello Gmarwick,
    We have got your concern I install, SEO Yoast.
    As if now it is working fine at our end.
    Kindly follow the below step mentioned in the image.
    Kindly check at your end,
    Let me know if have further doubts so that I can assist you.
