separate logo for mobile
Discussion in 'Woodpecker WordPress Business Theme' started by clukesic, Nov 9, 2015.
  1. clukesic
    clukesic New Member
    Is it possible to have a different logo display on mobile versions? Or when the screen goes below a certain size?
    Please advise.
    Yes, it is possible but would like to tell you that it would require some source code customization in the source code of the theme.
    Do let me know if you agree then we will do it for you.
  3. clukesic
    clukesic New Member
    Yes that would be great. I can send log in credentials to your enquiry@ email address?
    thanks
    While sending you credentials, please don't forget to mention this thread link as well..
