Hello, I would like to separate twee businesses from each other. For example selling and renting. If people have chooses selling and then click on show all listings. Then I want that people only see all the listings for selling.. I thought about subdomains but I want that people can log in with one account to both domains. Hope someone knows what I mean and have some advise. Thanks
Hello, There is one easy way to achieve this. 1) Create two category (selling and renting). 2) Assign selling category to all selling listings and renting category to all renting listing. 3) Now go to Appearance > Menus and create custom menu and add both categories there, To show them as main menu. Check image for reference. Above process will separate your listings. Try it it will work.
Hi Nitesh, I have done what you told but there is one problem. You have only listings with the tag CARS, but one part is for selling and the other part is for renting. Now if you click in the main menu on renting you will only see the cars for renting, that is oke. But now I want to use the search function and look for location and then all the cars are showing up. The cars for renting and for selling. That is just what I dont want to have. Yesterday I found for now the best solution. I've created for my wordpress a multi-site wordpress and having now two sites, one for selling and one for renting. So people can switch between both sites. If you select in the main menu for renting, then my website switch to the site for renting. If people use here the search function they only have results for renting.
