Services Section and Slider Questions
Discussion in 'BusinessGrow One Page WordPress Theme' started by renarts, Mar 10, 2014.
  1. renarts
    renarts Member
    Good day.
    A couple of questions for the theme:
    1. I need to change the background color of the services circle when the mouse hovers over it. Found an answer on your support thread (http://www.inkthemes.com/community/threads/services-image-color-zoom.10718/) but frankly it is unclear which part of the code I should change. I tried using it but it turns the color to blue including the circular border around the image. If I want to change just the background what code do I need and which part should I change? Also is there a way to add another service or make the size a bit smaller?
    2. Can I have the slider in a boxed layout rather than full-width?
    3. Is there a way to customise it so that it won't be too big or maybe use a different slider on the home page instead of this one? If yes, where would I need to put in the shortcode if I use a different slider?
    Thanks in advance for your help.
    1. Paste the code given below in Custom CSS section
    .ch-item:hover {
    box-shadow: inset 0 0 0 0 rgba(229, 15, 40, 0.4), inset 0 0 0 16px rgba(229, 15, 40, 0.4), 0 1px 2px rgba(229, 15, 40, 0.4);
    You can change the value of rgba as per your requirement to change the background color when hover on feature images.
    2. For this download the front-page.php file attached with this post and replace it with your theme existing front-page.php file.
    File location
    themes\businessgrowtheme\front-page.php
    This will solve your second and third issue.
  3. renarts
    renarts Member
    Hi Piyush,
    Thank you for your response.
    The code worked successfully in changing the services circle color. I used the front-page.php file and did get the boxed slider. One problem though, I lost the right section of the Contact portion. The map is no longer there as well as the info I had on the address, phone, etc. I checked on the themes options and the info I put in are still there.
    Kindly check attached screenshot.
  4. Nitesh
    To make contact us area working go to the
    Appearance > Theme options > contact section and either set recaptcha off or add public and private keys.
    Check image for reference.
    Nitesh Raghuwanshi
