Hi How on earth do I set up the Cherry theme in wordpress to look like the demo on the marketplace website? I can't see any documentation or instructions ... Or how to videos ... Can you make a video please for installation and set up? Cheers
Hi, we have several video tutorials yes: If auto importer doesn't work: this is usually server time out error. You will need to contact your hosting provider about this error. You can also install demo content manually. You will find the demo content in the files you downloaded from Themeforest in directory DEMO_CONTENT. Check this tutorial for more informations: http://premiumcoding.com/cherry-multipurpose-wordpress-theme-online-documentation/#document-2 Look at : ONLY IF YOU DIDN’T IMPORT DEMO CONTENT VIA PMC IMPORTER! If you need any help our support staff can install theme for you. Also online documentation is available on the link above. Thanks and best regards
