SEVERAL ISSUES WITH BLACKWELL
Discussion in 'BlackWell-WordPress Business Theme.' started by cleanhom, Mar 28, 2017.
  1. cleanhom
    cleanhom New Member
    Nairobi
    When i insert the embed code for video and map, the iframe code appears on the front page. the sliders are interfering with the site loading, i have to close and open new tab to check changes, i can also observe slider counts in the search bar (#1, #2...
    smith likes this.
  2. Naveen
    Thank you for contacting us,
    I am afraid to say that, I was unable to locate the area in the theme...
    It would be better for us to understand your query with the help of edited screenshot.
    Naveen Kolhe
  3. cleanhom
    cleanhom New Member
    Nairobi
    Here are snapshots
  4. cleanhom
    cleanhom New Member
    Nairobi
    Regarding the issues with blackwell pro, i installed the previous version and it works very well - no issues. Which means the current pro has several code problems that needs to be identified. For now, i have installed the previous version pending your review on the current
    smith likes this.
  5. Naveen
    Kindly, share your WordPress admin credentials at [email protected] along with this thread URL:
    WordPress site login URL:
    WordPress admin username:
    WordPress admin password:
    We will check and do the needful.
    Warm Regards!
    Naveen Kolhe
  6. cleanhom
    cleanhom New Member
    Nairobi
    Thank you very much for your assistance and keep up with the good work!
  7. Naveen
    You are most welcome :)
