Several issues with Businessgrow Theme
Discussion in 'BusinessGrow One Page WordPress Theme' started by digihanger, Nov 1, 2013.
  1. digihanger
    digihanger New Member
    A great looking theme but having severe problems getting it to work properly. These are the major issues and its apparent across Firefox, Chrome and IE.
    Issue 1) The gallery section on the front page often does not load. When it does choose to load showing the hexagonal images which open as expected into the light-box it looks great. When I click onto one of the front page blog posts and go to the page then click again on the home page the gallery images have gone. All I see are the categories tags which don't operate anymore. If I revisit any other part of the site and then click 'back' in the browser usually the images in the gallery reappear. Its all very erratic and haphazard whether the images appear or not.
    Issue 2)
    Images placed in the posts ignore the text wrap settings in WP. The images default to 'no wrap' no matter if I align left, center or right.
    I have left the test site up, it just a test for the theme which I always do before trying to use it on a full blown site, you can see if you get the same problems here http://onlineaccountancy.org/
    Really want this theme to work its ideal for the site I have in mind but at the moment I am getting nowhere with it.
    1) I have checked your site in Firefox, Chrome and IE but not found any loading issue. Please share screenshot and browser version.
    It will help us to provide you exact solution.
    2) For image alignment paste this code in Custom CSS
    img.alignright {float:right; margin:0 0 1em 1em}
    img.alignleft {float:left; margin:0 1em 1em 0}
    img.aligncenter {display: block; margin-left: auto; margin-right: auto}
    a img.alignright {float:right; margin:0 0 1em 1em}
    a img.alignleft {float:left; margin:0 1em 1em 0}
    a img.aligncenter {display: block; margin-left: auto; margin-right: auto}
    I hope solution above will help you.
  3. digihanger
    Thanks for the help I appreciate that but I checked the test site again and its still the same.
    This is what I did.
    1) open http://onlineaccountancy.org
    2) check that the three gallery images can be seen on the page and they open up okay..
    3) click on the 'Recent Blogs' center pipework graphic titled 'installation' and go to that page
    4) click on the 'Business Grow' logo at top left to return to front page.
    Scroll down and the image files in the gallery are gone and the buttons showing the categories are inactive.
    That's what's happening across FF, IE and Chrome, for me anyway. I can't get these images up until I click back on the browser from action (3) above then they show no problem. Repeat the actions above from (1) and again they are gone.
    What it means is that anyone clicking on the 'Business Grow' logo, or whatever I substitute the image with, from anywhere within the site pages will no longer see the gallery files on the front page.
    If you are not seeing this then I have no where to go to fix the issue at my end, I'm at a bit of a loss.
    The image attached shows what I see when I come back to the page by clicking the business grow logo.
    Images gone and buttons inactive.
    For this demo I am using Firefox latest version 25 but it happens across IE and Chrome just the same.
    I want to develop the site but can't until I get this issue fixed.
    By the way just to make things worse the CSS code you gave me above does not fix the alignment issue either,
    the image refuses to change alignment, left or right, or to wrap the text.
    Sorry about this but I need to have a solution soon, hope you can help.
    best regards Barrie Taylor
  4. Gourav
  5. digihanger
    I downloaded and installed the new version but now although the original issue regarding the gallery not showing appears fixed I have more problems.
    I have reloaded another set of images to test the site but now I am getting a formatting issue in Firefox. The three blog post images on page one appear okay but the third one is offset lower down the page.
    Also in Firefox the gallery images do not open.
    Additionally the slider image has a gap on the left of the slider, its offset across the page.
    Finally the blog post images still do not obey the wrap settings left, right or center.
    In IE and Chrome the site displays fine except still the wrap settings on the post images are ignored.
    Thanks for the help so far I really want to solve this issue and will be patient while you look into.
    I left the test site up at http://onlineaccountancy.org
    best regards Barrie
  6. Nitesh
