Several issues with ClassiCraft Template
Discussion in 'ClassiCraft WordPress Theme' started by stephanrota, Oct 31, 2018.
  1. stephanrota
    stephanrota New Member
    Hi there,
    i have several issues with the ClassiCraft template on my site, can someone assist here?
    These are my main issues:
    - Main Menu is not showing
    - Google Maps does not work on Sidebar = > Error
    - Contact Form to contact Seller does not work,= > Error
    Stephan
  2. akbar92
    Greeting from InkThemes,
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    We will do the needful.
    Akbar
  3. stephanrota
    Hi Akbar,
    email sent, thanks for your support!
    Regards
    Stephan
  4. akbar92
    It looks like we do not have admin credentials.
    Kindly send us the admin credentials at [email protected].
    Akbar
  5. stephanrota
    Thanks for your support, works like it should now!!
    I‘ve sent you a mail with another small Issue, would be great if you could help.
    Great Support!
    Regards Stephan
  6. akbar92
    We have successfully received your credentials.
    We will let you know when the issue is fixed.
    Akbar
