Several Issues with Colorway Pro
Discussion in 'ColorWay WordPress Theme' started by novustech, Jan 20, 2014.
  1. novustech
    novustech New Member
    Hi I will be short and on point.
    My website is: www.novustech.ca
    Here are my issues:
    1. The Pages Navigation Menu (that is supposed to be visible on mobile instead of the regular menu is visible, in Chrome only, IE doesnt show it.
    2. I use Shopp plugin for ecommerce and for some reason the built in shop page from the plugin redirects to the homepage (www.novustech.ca/shop). This only happens with Colorway, i checked another theme and issue is not existent.
    3. Can the width of the page be easily modified (set to float on the whole screen width or a specific width?)
    4. The "motto" does not center
    5. The widgets on the right dont seem to center correctly
    6. Question, is there a way to put a widget area in the title? (near my logo)
    Thank you, I really appreciate it
    1. Could you please inform us that in which version of IE you are facing navigation problem.
    2. For this go to the Reading Settings panel (Settings > Reading) in your dashboard
    and follow the instruction shown in the image given below.
    3. It is not possible for us to do that with our theme because this theme is implemented on the Responsive 960 grid system.
    If we try to change the width of pages in the theme, then it will break the layout.
    4. Paste the code given below in Custom CSS section
    blockquote {
    text-align: center;
    5. Could you please specify us this issue with the help of screenshot images that which image is not align in center.
    6. Unfortunately there isn't a way to do that with our theme unless you custom code something up. Sorry.
  3. novustech
    Thanks Piyush,
    1. Issue disappeared...odd
    2. Issue disappeared...odd again
    3. Understood, thank you
    4. This one too fixed itself
    5. Again no issue anymore
    6. Understood...
    Looks like your theme is self healing. Or i may have been drunk that night...Everything looks good.
    Thank you for your immediate attention and great theme
