Is it possible to remove a shadow inside a certain slider? Not in all of them, but let's say, in slider number 3?
Hi, Greetings from InkThemes! Please paste the code given below in Custom CSS field (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard. Code: .imgpadding:nth-child(n) { background: none; } Hope it will resolve your issue Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
Hi, you can choose your desired image by adding slider number in place of n (in the above code).. Thanks & Regards! Priyanka InkThemes.com
Sorry, but the code you gave does not work: .imgpadding:nth-child(3) { background: none; } I used it to remove the shadow in slide number 3 and the shadow is still there.
Hi, Could you please provide us 'URL' of your site so that we can better assist you? Thanks & Regards! Priyanka InkThemes.com
URL is turboion.eu I would like to remove shadow for the slide number 3. Tha code you have provided is already applied.
Hi, Sorry...I have rechecked the code and would like to inform you that it's not possible to remove the effect from a particular slider... Hope you will understand.. Thanks & Regards! Priyanka InkThemes.com
Hi, Code is given below. Code: .flexslider .imgpadding { background: none; } Hope it will resolve your issue Thanks & Regards! Priyanka InkThemes.com
