my url is hickoryridgekennel.com. I am using a plugin called "who hit the page" and it gives you a short code to put on a page(s) so that you can see how many visitors you've had to your pages. Where can I put the short code on my home page that is will stay invisible and count my hits. I've set it on all other pages, but wasn't sure how to insert it into the home page since most of it is set up using the theme options control panel. Thanks!
Hello, You can put your shortcode in the footer widget area. Go to the Appearance > Widgets panel in your dashboard and drag & drop the text widget in the footer widget area and then paste your shortcode in the content area of text widget. This will solve your issue.
Hello! I am not using the footer widgets. I did remove the code in the styling options so that I could play with the widgets and when I put the short code [whohit]home[/whohit] it physically shows up on the page in the footer, rather than being invisible as it is on other pages. Any suggestions? the url is hickoryridgekennel.com. Thanks!
