This post was asking for what I need [http://www.inkthemes.com/community/threads/creating-a-testimonials-page.15455/] but it doesn't display the answer. What shortcode is used to make a separate Testimonial page from the theme? Thanks!
Hi, To add testimonial page you need to install WordPress plugins for Testimonial page. You can even try plugin: Testimonials Widget: https://wordpress.org/plugins/testimonials-widget/ Using it you can creates a separate testimonial page and generates a shortcode for it that you can use any where in the post. Regards, Sameer
Unfortunately, that Shortcodes area does not show on my theme. Am I missing something? I have version v1.0.2. It would be an awesome addition to this theme!
Hi gwindylyn! I am sorry for the last reply. Unfortunately there is no shortcode available for the built-in testimonial. I would like to recommend you to use "Easy Testimonial" plugin which will provide you the shortcode to use in different pages. Plugin link :- https://wordpress.org/plugins/easy-testimonials/ Thanks, Praveen
