Shortcode in Header
Discussion in 'Appointway WordPress Theme' started by lkodsmann, Sep 25, 2014.
  1. lkodsmann
    lkodsmann Guest
    I'd like to use a shortcode in the header section (where the top-right contact details go) - but right now, if I put my shortcode in, it gives me the shortcode text (instead of the correct shortcode output)...
    Is there a way that I can use this top-right area in the header for shortcode purposes?
    Thanks!
    Leanne
  2. Yogesh
    Yogesh Guest
    Use following line in header.php file as shown below in screenshot.
    _do_shortcode_(inkthemes_get_option('inkthemes_topright'));
    It will resolve your issue.
    Yogesh Bhade
  3. lkodsmann
    lkodsmann Guest
    Making that change in my header.php file doesn't seem to do the trick... when I make the modification in the screenshot, my homepage only displays my logo (the rest of the screen is blank/white)...
  4. Yogesh
    Yogesh Guest
    Replace code on line no. 55 in header.php file with following code.
    <p> <?php echo do_shortcode( stripslashes(inkthemes_get_option('inkthemes_topright')) ); ?></p>
    Yogesh Bhade
  5. lkodsmann
    lkodsmann Guest
    That worked perfectly, thank you so much!
