Shortcodes not parsing in Andrina fresh install
Discussion in 'Andrina WordPress Theme' started by reedphoto, Apr 14, 2016.
  1. reedphoto
    reedphoto New Member
    Since update to WP 4.5 shortcodes are not parsing in the theme. I noticed this today on an existing installation that goes back several versions to 2.1
    I have copied the site over to a staging server, installed a fresh copy of the most recent version of Andrina 3.3.0, turned off all plugins except one for testing. The short code shows in plain text instead of parsing.
    I then activated a different theme called responsive as a test and the shortcode parses fine.
    Perhaps it's related to changes in the shortcode API outlined here: https://www.gavick.com/blog/wordpress-shortcode-api-issues
    and here:
    https://github.com/websharks/s2member/issues/656
    Your insights are appreciated.
  2. reedphoto
    Here is some additional info. So far it is only an issue in the Feature Descriptions on the front page.
  3. priya
    Your Website URL:
    WordPress Username:
    Password :
  4. reedphoto
    Any progress on this ticket?
  5. priya
    I have already replied you at mail..
    Kindly check your email..
