Hi there, I installed SI CAPTCHA Anti-Spam and enabled it for login and registration pages. However, the captcha section is not shown at all in the pages. I switched to twenty fourteen theme and everything is fine. In my setup, I'm using a child theme of classicraft theme. I switched to use the parent theme to test with it. The issue still exists even when using the parent theme. I need this plugin to work, kindly help figure out why it is not working. Thanks, Mike
Hi Yogesh, SI CAPTCHA Anti-Spam plug is required for the Akismet plugin to protect the site from comment spam. Can you help fix this issue as another captcha plugin will not work with Akismet. I'm OK with another anti spam plugin other than Akismet if you can suggest one that's just as good or better than Akismet. I appreciate you assistance. Thanks, Mike
Hello, Google recaptcha plugin is better than Akismat. Here is the link for google recaptcha. https://wordpress.org/plugins/google-captcha/faq/ Thanks & Regards Yogesh Bhade
Hi Yogesh, I uninstalled Akismat and SI CAPTCHA Anti-Spam . Then I installed google recaptcha, activated it and signed up for an account. However, the same issue still exists. Captcha is not visible on the page and when you fill out the registration form, the captcha error is encountered. Kindly, assist. Thanks, Mike
Hello, This is not a theme issue, try Google captcha after deactivation all plugins it may generate errors because of other plugins. http://wordpress.org/plugins/google-captcha/installation/ Follow steps: -Download google captcha plugin from wordpress.org -Install this plugin and activate -Go for the setting of this plugin -Generate private and public key using google by clicking on link -Fill private and public key in captcha settings. -Get your short code -Go to the (Appearance ->Editor ->template-contact.php ) -Paste like this short code echo do_shortcode('[bws_google_captcha]') -update file If this plugin do not resolve your issues try other anti spam plugins. Thanks & Regards Pramod
Hi Pramod, Thanks for your reply. I'll try it on a fresh installation without any plugins. Thanks, Mike
