Hi there.. I have the PhotoMaker Theme installed and when you click on the little box on the right hand side that makes the menu appear and disappear, nothing happens. It is totally unresponsive on Mobile Devices. When you touch the right corner menu box, it just stays stuck and does't show the menu... The DEMO Theme on your site works perfectly... Any idea why this is happening? Thanks in advance for your speedy response!
Hello, If you have plugin installed then please deactivate all plugins to see if this resolves the problem? If this works, re-activate the plugins one by one until you find the problematic plugin(s). It will work. If not then please share your website link. Thanks & Regards Nitesh Raghuwanshi
Thank you for your response... There are No Plugins installed. This is a Fresh WP installation only with the Photomaker theme on it. the site is www.johncunill.com It does not work on the computer, when you click the little box, the menu should slide in and out and it is just stuck, Does not work at all in Mobile. Thank you in advance for your help!
Hello, Sorry for the delay. Please provide the following information listed below. Thread Link: http://www.inkthemes.com/community/threads/side-menu-does-not-respond.13151/ Your Website URL: WordPress Username: WordPress Password: Send this information on our email at [email protected] I will check and resolve your issue. Thanks & Regards Nitesh Raghuwanshi
