Sidebar Widgets help
Discussion in 'Appointway WordPress Theme' started by filmworks7, Apr 25, 2016.
  1. filmworks7
    filmworks7 Member
    Greetings!
    I have 2 questions:
    I would like to add a calendar UNDER the MAP.
    However when I add the calendar widget it places it on very top Right.
    SO how do I move it under the map?
    Also
    When I get the embed code for google maps at address you have, it gives me a link, not an iframe code. Not sure if that is new for google maps or what. But do you know how I can get iframe fro location?
    Thanks!
    Regarding your first issue, I would like to add a calendar UNDER the MAP.
    Please follow the screenshots given below.
    For the second issue,
    Kindly follow the video given below.
    Link: http://screenpresso.com/=ROxjb
  3. filmworks7
    filmworks7 Member
    Hi There
    So I tried what you said to do, and it ended up making my sidebar completely blank.
    You can see the code I did below for reference.
    I should point out that I made the appointment bar inactive. Does that matter?
    Here is how I am trying to set up sidebar (with no appointment calendar)
    1-Time Box on top
    2-Location Box
    3-Map
    4-Calander on bottom
    4 <div class="sidebar home">
    <?php //if (is_active_sidebar('home-page-widget-area')) : ?>
    <?php
    dynamic_sidebar('home-page-widget-area');
    endif;
    $widget_active = str_replace(' ', '', strtolower(appointway_get_option('widget_activate')));
    if ($widget_active == 'both') {
    if (function_exists('ink_appoitment')) {
    Placed it here
    </div>
    78 <?php if (is_active_sidebar('home-page-widget-area')) : ?>
    <?php
    endif;
    echo '<div class="sidebar-widget">';
    echo '<div class="default_plugin">';
    ink_appoitment();
    echo '</div>';
    echo '</div>';
    if (function_exists('appointway_leadform'))
    appointway_leadform();
    }elseif ($widget_active == 'appointment') {
    ink_appoitment();
    echo '</div>';
    echo '</div>';
    } elseif ($widget_active == 'leadcapture') {
    </div>
    Please send us your dashboard details at [email protected] along with this thread link and I will do it for you..
  5. filmworks7
    filmworks7 Member
    Thanks Priyanka
    I have done so.
    Take Care
  6. priya
    Thanks for the details...
    We will get back to you soon...
  7. priya
    Your issue has been resolved..
    Kindly check your site..
