Sidebar Widgets: Modifications
Discussion in 'BizWay WordPress Theme' started by drkmbrown, Feb 14, 2014.
  1. drkmbrown
    drkmbrown Member
    How, in widgets, do I do the following:
    1. Increase the space between widgets
    2. change the font color of the Widget Titles
    3. Remove the faint lines between the widgets.
    Here is a link to see the widgets I have on my sidebar
    http://www.drkwamebrown.com/join
  2. drkmbrown
    drkmbrown Member
    Also, how do I add a new widget space to the sidebar?
  3. Nitesh
    1) You can add blank <p></p> tag in the sidebar widget. To increase space.
    2) Paste this code in Custom CSS
    .sidebar h3 {
    font-color: YOUR FONT COLOR;
    3) Paste this code in Custom CSS
    .sidebar {
    border-left: none;}
    Nitesh Raghuwanshi
  4. drkmbrown
    drkmbrown Member
    Thanks Nitesh. The code to remove the faint lines between the widgets (on top of and below) did not work. What about creating new sidebar widget spaces? I only have two.
  5. Nitesh
    For faint line replace previous code with the code given below.
    .sidebar h3 {
    border-bottom: none;
    There is no widget limit for the sidebar.
    You can add multiple widgets in the primary and secondary widget area.
    Nitesh Raghuwanshi
