Site Errors in Firefox, Edge - OK in chrome
Discussion in 'ButterBelly WordPress Theme' started by briangladstone, Mar 26, 2018.
  1. briangladstone
    briangladstone Member
    My website is www.briangladstone.com
    It works fine in chrome. The slide appears ok, and the middle section is disabled (CSS code supplied you).
    In Firefox, Edge, IE the slider will not appear; and the middle section (should be disabled) is visible. Can you advise how to make the slider appear, and the middle section disappear?
    Your prompt response is requested. Thank you
    Brian Gladstone
    smith likes this.
  2. akbar92
    Greeting from InkThemes,
    We need WordPress admin credentials to figure out the issue.
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    Akbar
