Site not Displaying
Discussion in 'RoadFighter WordPress Theme' started by medinachaz, Jan 30, 2014.
  1. medinachaz
    medinachaz Member
    Hi guys, my website is not displaying at all and I don't know why. Please help me trouble shoot this issue . Thank you.
    RedCastleWebDesign.com
  3. medinachaz
    medinachaz Member
    Okay, I re-installed the RoadFighter Theme. The blank screen only happens when I use roadfighter.
  4. Piyush
    This issue maybe because of plugin (if installed). So please deactivate all plugins to see if this resolves the problem? If this works, re-activate the plugins one by one until you find the problematic plugin(s).
  5. medinachaz
    medinachaz Member
    Thanks guys, I really appreciate your help. I will find out and get back to you.
  6. medinachaz
    medinachaz Member
    Okay, so I deactivated and deleted all plugins. The site does not display properly.
    I found out that the home page is not working properly...
    However if I were to put in for example..
    RedCastleWebDesign.com/Page
    The page will show up properly.
    I'm not sure if it's an error in my HTML.
    I backed up my HTML from when there was no errors and the site still doesn't display so I'm not sure, because I pasted the text that I backed up from when there was no issues..
    I am going to continue to trouble shoot this issue myself. Thank you again for all of your help.
    -Medina
  7. Piyush
  8. Piyush
