Site Not Mobile Responsive
Discussion in 'Blackriders WordPress Theme' started by gmarwick, May 6, 2016.
  1. gmarwick
    gmarwick New Member
    Hi My site is not showing up correctly on my phone. The header section seems to stretch off the page.
    Any idea why it is doing this?
  2. nitin
    nitin Guest
    Could you please provide us URL of your website so that we could check the things at our end and could let you know the issue?
    We would be glad to assist you.
    Nitin
  3. gmarwick
    gmarwick New Member
    Hello, Grant..
    Please paste the code given below in Custom CSS field (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard.
    .logo img {
        width: 100%;
  5. elehotzky
    elehotzky New Member
    Hi! I'm having a similar issue and while Priya's code fixed it so now my home page feature settings and bottom feature settings are showing, but my home slider image/heading/description is still stretched off. Can you please help me figure out what I need to change to include the home slider image/description on the mobile site? Web address is www.gimmesquats.com
    Thank you!
    -Erica
  6. priya
    Hello Erica,
    I have checked your site and would like to tell you that you are using 1.0.3 version of the theme whereas 1.1.2 is available in the members area..
    So if you haven't customized source code of the theme, you are kindly suggested to reinstall the latest version of the theme from the members area.
    Download the Compass theme by logging in your members account:
    Next, you have to extract the zip file and rename that folder compass like compass_new,
    Again, you would need to create a zip file of that renamed folder (say: compass_new.zip),
    Then, activate your theme,
    elehotzky likes this.
  7. elehotzky
    Thank you, Priyanka! That solved the problem of the slider image not showing up on the mobile page, however I'm still not seeing the description part of the slider come in. The pictures are clickable, but I was hoping to get the gray description banners next to them as well. Is there anything I can edit to get that?
    Thank you!
  8. priya
    I would like to inform you that we usually disable the slider description area from mobile view due to responsiveness issue...
    Hope you will understand..
