Site opens with menu in top left
Discussion in 'BlackWell-WordPress Business Theme.' started by leadology, Oct 22, 2015.
  1. leadology
    leadology Member
    It is a distraction being so big there. Is there a way to switch it so the user can select it later instead of opening full size upon landing on the homepage? Thank you, mark;-)
    Could you please provide us 'URL' of your site with some edited screenshot so that we can better assist you?
  3. leadology
    leadology Member
    We got your concern..
    You are suggested to replace the blackwelltheme\js\bigslide.js file with the below code.
    /*! bigSlide - v0.4.3 - 2014-01-25
    * http://ascott1.github.io/bigSlide.js/
    * Copyright (c) 2014 Adam D. Scott; Licensed MIT */
    (function($) {
        $.fn.bigSlide = function(options) {
            'use strict';
            var settings = $.extend({
                'menu': ('#push_panel'),
                'push': ('.push'),
                'side': 'left',
                'left': 'margin-left',
                'menuWidth': '300px',
                'speed': '300',
                'tpl_container': ('.container_24'),
                'menu_icon': ('.menu-link'),
            }, options);
            var menuLink = this,
                    menu = $(settings.menu),
                    push = $(settings.push),
                    container = $(settings.tpl_container),
                    menu_icon = $(settings.menu_icon),
                    width = settings.menuWidth;
            var positionOffScreen = {
                'position': 'fixed',
                'top': '0',
                'bottom': '0',
                'settings.side': '-' + settings.menuWidth,
                'width': settings.menuWidth,
                'height': '100%'
            var animateSlide = {
                '-webkit-transition': settings.side + ' ' + settings.speed + 'ms ease',
                '-moz-transition': settings.side + ' ' + settings.speed + 'ms ease',
                '-ms-transition': settings.side + ' ' + settings.speed + 'ms ease',
                '-o-transition': settings.side + ' ' + settings.speed + 'ms ease',
                'transition': settings.side + ' ' + settings.speed + 'ms ease'
            var animateMarginSlider = {
                '-webkit-transition': settings.left + ' ' + settings.speed + 'ms ease',
                '-moz-transition': settings.left + ' ' + settings.speed + 'ms ease',
                '-ms-transition': settings.left + ' ' + settings.speed + 'ms ease',
                '-o-transition': settings.left + ' ' + settings.speed + 'ms ease',
                'transition': settings.left + ' ' + settings.speed + 'ms ease'
          menu.css('left', '0');
            push.css(settings.left, settings.menuWidth);
            menu.css(positionOffScreen);
            push.css(animateMarginSlider);
            menu.css(animateSlide);
            container.open = function() {
                container.css(settings.left, 'auto');
            container.close = function() {
            menu_icon.open = function() {
                menu_icon.css('right', '-48px');
            menu_icon.close = function() {
                menu_icon.css('right', '5px');
                $('.logo').css('padding-top', '90px');
            container.open();
            menu.open = function() {
                menu._state = 'open';
                menu.css(settings.side, '0');
                push.css(settings.left, width);
                container.open();
            menu.close = function() {
                menu._state = 'closed';
                menu.css(settings.side, '-' + width);
                push.css(settings.left, '0');
                container.close();
            var ua = navigator.userAgent;
            var event = (ua.match(/iPad/i)) ? 'touchstart' : 'click';
            $(menu).trigger(event);
            menuLink.on(event + '.bigSlide', function(e) {
                e.preventDefault();
                var viewPortWidth = $(window).width();
                if (menu._state == 'open') {
                    menu.close();
                    if (viewPortWidth < 600) {
                        menu_icon.open();
                } else {
                    menu.open();
                        menu_icon.close();
            var detectViewPort = function() {
                if (viewPortWidth < 960) {
                    container.close();
                } else {
                    menu.css(settings.side, '-300px');
                    push.css(settings.left, 'auto');
                    container.open();
            detectViewPort();
            $(window).ready(function() {
                detectViewPort();
    //        menuLink.on('touchend', function(e) {
    //            menuLink.trigger(event +'.bigSlide');
    //            e.preventDefault();
            return menu;
    }(jQuery));
    jQuery(document).ready(function() {
        jQuery('.menu-link').bigSlide();
    here is the screenshot of the file where you have replaced the code..
  5. leadology
    leadology Member
    @priyanka thank you very much! works perfectly now. have a great day, mark;-)
