Can you tell me the max size you can have the First Feature Section and the Third Feature Section on the Homepage Second Featured Section area so it doesn't get cut off? The recommended sizes are not listed.
Hi, Greetings from InkThemes, I would like to let you know that as such there is no limit over the content you enter in the featured area content. If you are facing the issue of text getting cut-off, to determine and fix the issue, we need access to your dashboard. So, send us your website WordPress login details at [email protected] along with the thread link. Your Website URL: WordPress Username: Password : We will try to do the changes ASAP. Thanks & Regards! Nitin InkThemes.com
